Förenkling av xrandr
Inläggav Osprey » lör feb 03, 2024 1:17 am
Många gånger då jag bootat upp från en hemmagjord pinne, så har jag hamnat med en märklig skärmupplösning och drömmen hade ju då varit att bara kunna skriva "kommdo det-jag-vill-ha". I Linux finns ju då "xrandr", men det är delvis lite bökigt.
Så därför har jag hackat ihop ett script som gör det enkelt... :D
Det är bara att skriva "xr den-upplösning-du-vill-ha" och ja, jag har kallat scriptet för "xr", men det väljer man själv.
Scriptet är förberett för wayland, men den biten finns inte ännu.
PROTOCOL=$(echo "$XDG_SESSION_TYPE")
if [[ $PROTOCOL != "x11" ]]; then
   echo "-As the protocol is $PROTOCOL, we cannot continue (only x11 is supported)"
   echo
   exit
fi
function usage {
   less << EOD
usage:  $CMDNAME [function] [WIDTHxHEIGTH]
   If "WIDTHxHEIGHT" is specified, this automatically implies a "set" function.
   FUNCTIONS:
   -c | --current
      Show current resolution, this is also what is shown if "$CMDNAME" is run
      without any specified function.
   -d | --define
      Define a new resolution for this monitor. The specified resolution must
      be defined by the VESA standard. If the specified resolution is already
      defined, a message is written and no further definition is made.
   --dryrun
      Performs all the actions specified except that no changes are made.
   -h | --help
      Show this.
   -i | --inter | --interactive
      All defined resolutions for this monitor is shown and it is possible
      to select one of them, by entering its number. It is also possible to
      enter "0" and then specify which resolution that is wanted.
      Running this and selecting the number for 1920x1080 (eg. "1" ) has the
      same result as running "$CMDNAME -l" to see that it is "1" and then run
      "$CMDNAME 1" (or "$CMDNAME 1920x1080" first.
      Running interactive and specifying "0" and then enter "1920x1080" has
      the same result as running "$CMDNAME 1920x1080" or probably "$CMDNAME 1".
   -l | --list
      List all modes are currently defined for this monitor. It only shows all
      resolutions that are defined for the monitor, it does not show all possible
      resolutions.
   --rm | --remove
      Remove a defined resolution. Generally there is no need for this function
      as defined resolutions is removed by a reboot. It is not possible to remove
      any resolution defined by the system.
      This function sometimes misses, due to a bug in xrandr, but however a reboot
      works.
   -r | --reset
      Reset monitor to the previous resolution. Most often this is the original
      resolution.
      The "previus" resolution is only saved the first time a change of resolution
      is made. Therefore a reset after a number of changes only resets to the first
      resolution.
      The "reset-file" is deleted after each reset, but can however remain after a
      certain reboot.
   -v | --vesa
      List possible resolutions that are defined by VESA. This does not imply
      that the resolutions are supported by the actual monitor.
      The purpose of this function is not to be a complete list of all possible
      resolutions, but to give tips on the most common ones if none are available
      via "-l" for the monitor in question.
   -m MON | --mon=MON | --monitor=MON
      Specifies which monitor to operate on. If not specified it is assumed
      that only one monitor exists.
   Both "-c" and "-l" performs an exit when the info is shown. If both are specified
   only the first function will thus be performed. This is also the same when a resolution
   ("set") is specified. A resolution setting is always superseeded if "-c" or "-l" is
   specified.
   FILES:
      The command uses a file called ".xr" in the users home-directory, so do not use
      this name for anything else.
   EXAMPLES:
      $CMDNAME 5
         Setup this monitor to run with the resolution defined by line #5 as
         shown by "$CMDNAME -l".
      $CMDNAME 1920x1080
         Setup this monitor to run with the resolution "1920x1080". It only works if
         1920x1080 is already defined. Check with "--list" and use "--define" if it
         is not.
      $CMDNAME -c | --current
         Show current resolution - this is also default if no other action is specfied.
      $CMDNAME -d 1920x1080 | --define=1920x1080
         Define the resolution "1920x1080" for this monitor and change to it. If 1920x1080
         is already defined, a new definition will not be made.
      $CMDNAME -l | --list
      $CMDNAME -m MON | --mon=MON | --monitor=MON
         Specify that the monitor to be used are for example "HDMI-1" or "VGA". Of course
         a function to be performed must also be specified, otherwise only the current
         resolution will be shown.
         If there only exist one monitor, it is not needed to specify this.
      $CMDNAME -v | --vesa
         Show the standard resolutions defined by VESA, as I have found so far. This script
         will not try define anything else. Edit this script and add extra resolutions if
         you want and know what you are doing.
EOD
function checkIfResolIsDefined {
   RSL=$1
   ResolIsDefined=false
   if [[ $PROTOCOL == "x11" ]]; then
      LINES=$(xrandr | sed -e 's/^[[:space:]]*//' | grep "^[0-9]" | awk '{ print $1 }')
   elif [[ $PROTOCOL == "wayland" ]]; then
      # We will never reach here as "$PROTOCOL==wayland" has already performed an exit...
      # It is just here for future development...
      RESOL="<wayland>"
      return 1
   else
      # We will never reach here as "$PROTOCOL==other" has already performed an exit...
      RESOL="<other>"
      return 1
   fi
   origIFS=$IFS
   IFS=$'\n'
   for LINE in $LINES; do
      if [[ $RSL == $LINE ]]; then
         ResolIsDefined=true
         RESOL=$RSL
         break
      fi
   done
   IFS=$origIFS
   if [[ $ResolIsDefined == false ]]; then
      return 1
   fi
   return 0
function currentModes {
   SPECIFIED_MODE=$1
      MODES=$(xrandr | sed -e 's/^[[:space:]]*//' | grep "^[0-9]" | awk '{ print $1 }')
      MODES="<wayland>"
      return 1
   else
      MODES="<other>"
      return 1
   fi
   for MODE in $MODES; do
      if [[ $SPECIFIED_MODE == $MODE ]]; then
         return 0
      fi
   done
   return 1
function doReset {
   getMonitor
   if [[ -r ~/.xr ]]; then
      RESOL=$(cat ~/.xr)
      echo "-Resetting resolution to $RESOL"
      echo "=> xrandr $OPT --output $MONITOR --mode $RESOL"
      rm ~/.xr
   else
      echo "-No previous resolution found..."
   fi
   echo
function findMonitor {
   NUM=$1
      xrandr --listmonitors | tail -n +2 | sed 's/^[[:space:]]*//' | grep "^$NUM:" | awk '{ print $4 }'
      echo "<wayland>"
   else
      echo "<unknown>"
   fi
function getMonitor {
   if [[ -z $MONITOR ]]; then
         NMON=$(xrandr --listmonitors | grep "Monitors:" | awk '{ print $2 }')
         NMON="0"
      else
         NMON="0"
      fi
      if [[ $NMON -gt 1 ]]; then
         echo "-More than one monitor exists, you have specify which one to use with name or number"
         echo "-Existing monitors:"
         echo
         showMonitors
         echo
         read -p "_Monitor: " IN
            MONITORS=$(xrandr --listmonitors | sed -e 's/^[[:space:]]*//' | grep "^[0-9]" | awk '{ print $4 }')
            MONITORS="<wayland>"
         else
            MONITORS="<other>"
         fi
         isnum $IN
         if [[ $? == 0 ]]; then
            MONITOR=$(findMonitor $IN)
         else
            MONITOR=$(toupper $IN)
         fi
         if [[ ! -z $MONITOR ]]; then
            monitorExist $MONITOR
            if [[ $? != 0 ]]; then
               echo "-Specified monitor $MONITOR not found..."
               echo
               exit
            fi
            echo "-Monitor specified as $MONITOR"
            echo
         else
            echo "-Specified monitor not found..."
            echo
            exit
         fi
      else
            MONITOR=$(xrandr | grep -e " connected [^(]" | cut -d\  -f1 | xargs)
            echo "-Monitor implicitly set to $MONITOR (only 1 exists)..."
            MONITOR="<wayland>"
         else
            MONITOR="<other>"
         fi
      fi
   else
      else
         echo "-Monitor $MONITOR does not exist..."
         echo
         exit
      fi
   fi
function isnum {
   if [[ $1 =~ ^[0-9]+$ ]]; then
      return 0
   fi
   return 1
function listDefined {
   #xrandr | grep "^   "[0-9] | grep -v none
   echo '-Preferred resolutions is denoted by "+" (plus)'
   echo '-Current resolution is denoted by a "*" (asterisk)'
   echo '-A resolution that ends with an "i" means "interlaced" and a "p" means "progressive"'
   echo "-(Interlaced is mostly used for CRT monitors)"
   echo
      xrandr | sed -e 's/^[[:space:]]*//' | grep "^[0-9]" | cat -n
      echo "<wayland>"
   else
      echo "<unknown>"
   fi
   echo
function monitorExist {
   MN=$1
   FOUNDMON=false
      MONITORS=$(xrandr --listmonitors | tail -n +2 | awk '{ print $4 }')
      for MONIT in $MONITORS; do
         if [[ $MONIT == $1 ]]; then
            FOUNDMON=true
            return 0
         fi
      done
      echo "<wayland>"
   else
      echo "<unknown>"
   fi
   return 1
function number2resol {
   IN=$1
   NumToResol=false
      #LINES=$(xrandr | grep "^   "[0-9] | cat -n | sed -E 's/^[[:space:]]+//')
      LINES=$(xrandr | sed -e 's/^[[:space:]]*//' | grep "^[0-9]" | cat -n)
      RESOL="<wayland>"
      return 1
   else
      RESOL="<other>"
      return 1
   fi
   origIFS=$IFS
   IFS=$'\n'
      NUM=$(echo $LINE | awk '{ print $1 }')
      if [[ $NUM == $IN ]]; then
         NumToResol=true
         break
      fi
   done
   IFS=$origIFS
   if [[ $NumToResol == true ]]; then
      RESOL=$(echo $LINE | awk '{ print $2 }')
   else
      RESOL=""
      return 1
   fi
   return 0
function removeResol {
   RESOL=$1
      echo
      showMonitors
      echo
      isnum $IN
      else
      fi
            echo
            exit
         fi
         echo
      else
         echo
         exit
      fi
   else
   fi
   checkIfResolIsDefined $RESOL
      echo "=> xrandr $OPT --delmode $MONITOR $RESOL 2> /dev/null"
      echo "=> xrandr $OPT --rmmode $RESOL 2> /dev/null"
         echo "-Remove failed, if it is a user defined resolution it  will be removed at next reboot..."
      fi
      echo
      exit
   else
      echo "-Resolution $RESOL is not defined..."
      echo
      exit
   fi
function setupDefine {
   ASK=$1
   MODE=$2
   if [[ $ASK == "yes" ]]; then
      read -p '_Enter "WIDTHxHEIGHT": ' MODE
      if [[ -z $MODE || $MODE == "q" || $MODE == "Q" ]]; then
         echo
         exit
      fi
   fi
   WxH=$(echo $MODE | awk -F \_ '{ print $1 }')
   checkIfResolIsDefined $MODE
      DEFINE=false
      RESOL=$WxH
      echo "-Resolution $MODE is already defined for this monitor..."
      return 0
   fi
   vesaStd $WxH
      echo "-Unsupported resolution (no such VESA standard) - $WxH..."
      echo
      exit
   fi
   DEFINE=true
   FREQ=$(echo $MODE | awk -F _ '{ print $2 }')
   WIDTH=$(echo $WxH | awk -F x '{ print $1 }')
   HEIGHT=$(echo $WxH | awk -F x '{ print $2 }')
   MODE=$(cvt $WIDTH $HEIGHT | grep -i modeline | awk '{ $1=""; print $0 }' | sed -E 's/^[[:space:]]+//')
   NAME=$(echo $MODE | awk '{ print $1 }' | sed 's/\"//g' | awk -F _ '{ print $1 }')
   LINE=$(echo $MODE | awk '{ $1=""; print $0 }' | sed -E 's/^[[:space:]]+//')
   MODELINE="$NAME $LINE"
   MODSET=true
   RESOL=$WxH
   currentModes $WxH
function showCurrent {
      CURRENT=$(xrandr | sed -e 's/^[[:space:]]*//' | grep "^[0-9]" | grep \* | awk '{ print $1 }')
      CURRENT="<wayland>"
   else
      CURRENT="<other>"
   fi
   echo "-Current resolution is:  $CURRENT"
   echo
function showFunctions {
   if [[ $CURRENT == true ]]; then
      echo "   current  - yes"
   else
      echo "   current  - no"
   fi
   if [[ $HELP == true ]]; then
      echo "   help     - yes"
   else
      echo "   help     - no"
   fi
   if [[ $INTER == true ]]; then
      echo "   inter    - yes"
   else
      echo "   inter    - no"
   fi
   if [[ $LIST == true ]]; then
      echo "   list     - yes"
   else
      echo "   list     - no"
   fi
   if [[ $RESET == true ]]; then
      echo "   reset    - yes"
   else
      echo "   reset    - no"
   fi
   if [[ $RM == true ]]; then
      echo "   rm       - yes"
   else
      echo "   rm       - no"
   fi
   if [[ $VESA == true ]]; then
      echo "   vesa     - yes"
   else
      echo "   vesa     - no"
   fi
   if [[ $SPEC == true ]]; then
      echo "   spec     - yes  (specified resolution)"
   else
      echo "   spec     - no   (specified resolution)"
   fi
function showMonitors {
      xrandr --listmonitors | grep -v Monitors:
      echo "<wayland>"
   else
      echo "<other>"
   fi
function toupper {
   echo $1 | awk '{ print toupper($0) }'
function vesaList {
   cat << EOV
This is not a complete list of all possible resolutions. It is only tips about common resolutions
that possibly can be defined if there are to few pre defined as shown by "-l".
To define resolutions other than these, the script must be edited. The idea behind this, is to
prevent for unreasonable resolutions.
EOV
#      4:3
   echo "   4:3"
   echo "     3840x2880"
   echo "     3200x2400"
   echo "     2560x1920"
   echo "     2048x1536"
   echo "     1920x1440"
   echo "     1600x1200"
   echo "     1400x1050"
   echo "     1280x960"
   echo "     1024x768"
   echo "     800x600"
   echo "     640x480"
   echo
#      5:4
   echo "   5:4"
   echo "     1280x1024"
   echo
#      15:9
   echo "   15:9"
   echo "     1280x768"
   echo
#      16:9
   echo "   16:9"
   echo "     5120x2880"
   echo "     4264x2400"
   echo "     3408x1920"
   echo "     2728x1536"
   echo "     2560x1440"
   echo "     2128x1200"
   echo "     1920x1080"
   echo "     1864x1050"
   echo "     1704x960"
   echo "     1360x768"
   echo "     1280x720"
   echo "     1064x600"
   echo "     848x480"
   echo
#      16:10
   echo "   16:10"
   echo "     4608x2880"
   echo "     3840x2400"
   echo "     3072x1920"
   echo "     2456x1536"
   echo "     2304x1440"
   echo "     1920x1200"
   echo "     1728x1080"
   echo "     1680x1050"
   echo "     1536x960"
   echo "     1224x768"
   echo "     1152x720"
   echo "     960x600"
   echo "     768x480"
   echo
function vesaStd {
   wxh=$1
#      4:3
   if [[ $wxh == 3840x2880 ]]; then
      return 0
   elif [[ $wxh == 3200x2400 ]]; then
      return 0
   elif [[ $wxh == 2560x1920 ]]; then
      return 0
   elif [[ $wxh == 2048x1536 ]]; then
      return 0
   elif [[ $wxh == 1920x1440 ]]; then
      return 0
   elif [[ $wxh == 1600x1200 ]]; then
      return 0
   elif [[ $wxh == 1400x1050 ]]; then
      return 0
   elif [[ $wxh == 1280x960 ]]; then
      return 0
   elif [[ $wxh == 1024x768 ]]; then
      return 0
   elif [[ $wxh == 800x600 ]]; then
      return 0
   elif [[ $wxh == 640x480 ]]; then
      return 0
#      5:4
   elif [[ $wxh == 1280x1024 ]]; then
      return 0
#      15:9
   elif [[ $wxh == 1280x768 ]]; then
      return 0
#      16:9
   elif [[ $wxh == 5120x2880 ]]; then
      return 0
   elif [[ $wxh == 4264x2400 ]]; then
      return 0
   elif [[ $wxh == 3408x1920 ]]; then
      return 0
   elif [[ $wxh == 2728x1536 ]]; then
      return 0
   elif [[ $wxh == 2560x1440 ]]; then
      return 0
   elif [[ $wxh == 2128x1200 ]]; then
      return 0
   elif [[ $wxh == 1920x1080 ]]; then
      return 0
   elif [[ $wxh == 1864x1050 ]]; then
      return 0
   elif [[ $wxh == 1704x960 ]]; then
      return 0
   elif [[ $wxh == 1360x768 ]]; then
      return 0
   elif [[ $wxh == 1280x720 ]]; then
      return 0
   elif [[ $wxh == 1064x600 ]]; then
      return 0
   elif [[ $wxh == 848x480 ]]; then
      return 0
#      16:10
   elif [[ $wxh == 4608x2880 ]]; then
      return 0
   elif [[ $wxh == 3840x2400 ]]; then
      return 0
   elif [[ $wxh == 3072x1920 ]]; then
      return 0
   elif [[ $wxh == 2456x1536 ]]; then
      return 0
   elif [[ $wxh == 2304x1440 ]]; then
      return 0
   elif [[ $wxh == 1920x1200 ]]; then
      return 0
   elif [[ $wxh == 1728x1080 ]]; then
      return 0
   elif [[ $wxh == 1680x1050 ]]; then
      return 0
   elif [[ $wxh == 1536x960 ]]; then
      return 0
   elif [[ $wxh == 1224x768 ]]; then
      return 0
   elif [[ $wxh == 1152x720 ]]; then
      return 0
   elif [[ $wxh == 960x600 ]]; then
      return 0
   elif [[ $wxh == 768x480 ]]; then
      return 0
   else
      return 1
   fi
echo
TEMP=`getopt -ocdhilm:rv --long current,define,dryrun,help,inter,interactive,list,mon:,monitor:,rm,remove,vesa,reset -n $(basename $0) -- "$@"`
if [[ $? -ne 0 ]]; then
   usage
   exit
fi
eval set -- "$TEMP"
MODELINE="<not created as we are not defining a new mode>"
RESNAME="<not created as we are not defining a new mode>"
OPT=""
CURR=false
CURRENT=false
DEFINE=false
DRYRUN=false
HELP=false
INTER=false
LIST=false
NONE=true
RESET=false
RM=false
SPEC=false
VESA=false
MODSET=false
let COUNT=0
CMDNAME=$(basename $0)
while true; do
   case $1 in
      -c|--current)
         NONE=false
         let COUNT+=1
         CURRENT=true
         shift
      -d|--define)
         DEFINE=true
         shift
      --dryrun)
         DRYRUN=true
         OPT="--dryrun "
         shift
      -h|--help)
         NONE=false
         let COUNT+=1
         HELP=true
         shift
      -i|--inter|--interactive)
         NONE=false
         let COUNT+=1
         INTER=true
         shift
      -l|--list)
         NONE=false
         let COUNT+=1
         LIST=true
         shift
      -m|--mon|--monitor)
         shift
         MONITOR=$(toupper $1)
         shift
      --rm|--remove)
         NONE=false
         RM=true
         shift
      -v|--vesa)
         NONE=false
         let COUNT+=1
         VESA=true
         shift
      -r|--reset)
         NONE=false
         let COUNT+=1
         RESET=true
         shift
         shift
         break
         echo "-Got a star... [$1]"
         exit
   esac
done
P1=$1
P2=$2
P3=$3
P4=$4
if [[ ! -z $P1 ]]; then
   NONE=false
   SPEC=true
   #RESOL=$P1
   let COUNT+=1
fi
if [[ $COUNT -gt 1 ]]; then
   echo "-Only possible to specify one function..."
   echo "-Specified functions:"
   showFunctions
   echo
   exit
fi
ResolIsDefined=unknown
NumToResol=unknown
if [[ $CURRENT == true || $NONE == true ]]; then
   showCurrent
   exit
elif [[ $HELP == true ]]; then
   usage
   exit
elif [[ $LIST == true ]]; then
   listDefined
   exit
elif [[ $RESET == true ]]; then
   doReset
   exit
elif [[ $RM == true ]]; then
   removeResol $P1
   exit
elif [[ $VESA == true ]]; then
   vesaList
   exit
else   # -If $INTER or specified resolution - find which monitor
   getMonitor
fi
   # -Interactive was specified, so we have to show defined resolutions and ask about which to use.
      listDefined
      echo '_Enter a number that exists to change to that resolution, "0" to define a new resolution or "q" to quit.'
      echo "-It is not possible to enter resolution directly here!!"
      read -p '_Number: ' IN
      if [[ -z $IN || $IN == "q" || $IN == "Q" ]]; then
         echo
         exit
      elif [[ $IN != 0 ]]; then
         number2resol $IN
            echo "-No such resolution number - $IN..."
            echo
            exit
         fi
      elif [[ $IN == 0 ]]; then
         DEFINE=true
         setupDefine "yes"
      fi
      echo "-Session protocol is Wayland - not possible to fix yet-1..."
      echo
      exit
   else
      echo "-Session protocol is unknown - not possible to fix..."
      echo
      exit
   fi
elif [[ $SPEC == true ]]; then
   # -A resolution was specified in the command line, so we will check it out and possibly use it.
   X=$(echo $P1 | grep "x")
   if [[ ! -z $X ]]; then
      checkIfResolIsDefined $P1
      if [[ $DEFINE == true ]]; then
            setupDefine "no" $P1
         else
            echo "-Resolution $P1 is already defined for this monitor..."
         fi
      else
            echo "-Undefined resolution for this monitor - $P1..."
            echo
            exit
         fi
         RESOL=$P1
      fi
   elif [[ ! -z $P1 ]]; then
      number2resol $P1
         echo "-No such resolution number - $P1 (check with \"$(basename $0) -l\"..."
         echo
         exit
      elif [[ $DEFINE == true ]]; then
         echo "-Resolution $RESOL is already defined for this monitor..."
      fi
   else
      # We should never reach here, but add a message in case of...
      echo "-Unknown resolution error..."
   fi
fi
if [[ $CURRENT == $RESOL ]]; then
   echo "-Specified resolution is the same as current - no reason to change..."
   echo
   exit
fi
if [[ $MODSET == true ]]; then
   RESNAME=$(echo $MODELINE | awk '{ print $1 }' | sed 's/"//g')
fi
TRACE=false
if [[ $TRACE == true ]]; then
   echo
   echo "IN:              $IN"
   echo "SPEC:            $SPEC"
   echo "FOUNDNUM:        $FOUNDNUM"
   echo "ResolIsDefined:  $ResolIsDefined"
   echo "NumToResol:      $NumToResol"
   echo "DEFINE:          $DEFINE"
   echo "MONITOR:         $MONITOR"
   echo "MODELINE:        $MODELINE"
   echo "RESNAME:         $RESNAME"
   echo "RESOL:           $RESOL"
   echo
fi
if [[ ($SPEC == true && $ResolIsDefined == true) || ($NumToResol == true) ]]; then
      echo "-Setting resolution to $RESOL"
      if [[ ! -e ~/.xr ]]; then
         echo $CURRENT > ~/.xr
      fi
      echo "-Session protocol is Wayland - not possible to fix yet-2..."
   else
   fi
         echo "-Mode $WxH already exist, will not redefine it..."
      else
         echo "-Defining mode $RESOL"
         echo "=> xrandr $OPT --newmode $MODELINE"
         echo "=> xrandr $OPT --addmode $MONITOR $RESNAME"
      fi
      fi
      echo "-Session protocol is Wayland - not possible to fix yet..."
   else
   fi
else
   echo "-Resolution $IN not found..."
fi
echo
